Yup so can I... With Rubber linesdunno about the lines, but 4 disc brakes own on civics. I can stop instantly. and thats not even with drilled/slotted !
My experience says otherwise. If anything the feel was basically the same but less maintenance headaches the SS came with.SS lines improve brake feel more so than performance. Gives the pedal a more linear feel.
maybe from .5 mph, but not much faster.but 4 disc brakes own on civics. I can stop instantly
I cry everytime I see the brakes on a "real" sports car.Even top of the line SS lines are only good for 5-6 years.
Disc rears are overrated
:werd:Rear disk just look cooler, and are easier to replace pads![]()
http://en.wikipedia.org/wiki/Placeboyou can say that their aint no diff..lol...But i feel the diff. stops alot faster. my sedan with drums was shit.
chris, i'd agree with you, but I think it's not a placebo this time...his rear drums were probably worn out real good, so fixing those would have felt the same
prolly so. but I like the disc better either way. this is the same kinda arguement as saying which is better vtec or non vtec...if you have it, its better, if you dont have it, then it aint better.chris, i'd agree with you, but I think it's not a placebo this time...his rear drums were probably worn out real good, so fixing those would have felt the same
Not entirely a placebo
So you thought i was talking about SS lines? I wasnt. I have stock rear disc. I was saying they stop better than drums, not SS lines stop better. I don thave SS. i have stock.I was talking about SS Lines... Not Drums vs Disk...
I'm going to completely disagree with you here. SS brake lines(good quality ones) are the easiest way to get a better pedal feel. Instead of the crappy rubber lines expanding when the brakes are applied, SS lines don't expand and get rid of the squishy pedal feel.Get the brake lines that would have come on your conversion. And no, SS lines make little difference. If anything they are less durable over time (cheap lines that is).
