Ok so i have a 96 integra ls 5spd at the moment.
paid 300 for it not drivable, put a new master cylinder and changed the a/c pulley now its runs and has great a/c.
Now the antenna had been messed with , looks like someone put in an aftermarket antenna then removed it.
So near the brake lights there are a jumble of wires spliced together.
The brake light go on and off like theyre supposed to with running lights off (except for that when i press on and off the brakes the running lights turn on, and the clock gets brighter/flickers, and the ashtray light turns on and off) But when the running lights are on, the brake lights are on contantly, and the lights brighten/flicker when i apply brakes.
help
ok, also sometimes i try to start the car it doesnt start, the starter clicks it just wont turn over and i have to take a screw driver and jump the starter. And when it does start i have to hold the key all the way on for a second of two.. or three
95 CX Hatch
Nah, sounds like they put a single filament bulb in a dual socket. 1156 into 1157 socket will do that every time.
98 Civic LX
the breaks are more than likely wired into the running light circuit. grounds both when one gets power.
Ok so I put the driver door panel back on , and everything works on the car except the passenger window. Wtf
