Hey hello everyone im having some troubles with my brakes, im trying to bleed my brakes, and the brake liquid only comes off 2 wheels the one on the back right side and the one on the front left side... the other 2 wheels did not bleed anything any ideas off what is happening?? also this problem is after the wire tuck and adding a civic 00 proportioning valve, before the wire tuck i did not have any troubles with my brakes.... thanks a lot
91 CRX SI
What car is this in? Also did you double check the proportioning valve? Could swap the stocker back in. If you jack your car in the air and spin the wheel will your brakes stop the tires that won't bleed?
Post pics of the propostioning valve and the rest of your set up......
well the car is a 92 civic hb, the prop valve is a 00si one, i solved the problem today anyways i was a pinched line ... lol thanks a lot guys ...
