I have been searching and can't find the proper info that I seem to need to get the car to run properly.
I picked up a 99 DX that had an engine swap and didn't run. The previous owner had a mechanic buddy doing the work of changing a timing belt because the engine just died one day.
The engine is a D15B non VTech, the head is a P2A-10, and the ECM is a P2E-A12. The car had a D16Y7.
Upon tearing into the car, finally, I found that the timing tensioner hadn't been installed on the pivot peg or even tightened. I tightened the belt and it went almost all the way to the end of the tensioner slot. I timed it. It still wouldn't start, found that the coil was bad. I got it to start, but then it would die and just crank. I did this several times adjusting the ignition timing, and the cam timing by a tooth. With some digging and searching, I found out that the timing belt was too long (104 tooth) and got the proper one (103 tooth).
The car idled good after the new belt was installed, warmed up, and timed to the red mark. I revved it up a bit and everything was fine for a few minutes. Then I went to get on it and it died and wouldn't restart. I could get it to fire right back up by putting my hand over the throttle body for a split second.
After letting it sit overnight, it won't even start now, it just cranks and seems to try and pop every now and then. Thinking the cylinders were getting washed out and losing ring seal, I pulled the plugs and sprayed some WD-40 down the holes and put the plugs back in. It fired right up. It died when I hit the throttle, and it won't start again. I have had the timing light on it to monitor spark, and it has kept flashing.
I removed the throttle body and cleaned it and the IACV. While it was off, I pulled the fuel rail and cranked it to watch the fuel spray. They fired in sequence and sprayed evenly. They don't seem to be leaking, but they were still cold.
I am new to Honda's and any advice or guidance on the proper set-up would be greatly appreciated! Thanks in advance!
