41 - 60 of 66 Posts
COP and flex fuel. someone is going e85? good shit!
Discussion Starter #42
it's running on e85 since some years ;)
The problem is that e85 is not available here any more - so flex fuel is my rescue to drive back home from a race if i have not enough e85
do you have an electric boost solenoid installed? would be a great partner in crime with that octane sensor to be safe between home and race track.
Discussion Starter #44
of course. so you mean it should limit boost automatically with lower octane fuel?
Discussion Starter #47 (Edited)
yes, i really like it! i only have to paint it black to keep it as a sleeper ;)
after the first race (in a street category) i noticed some compressor surge noises... one problem solved and the next one follows =(
Discussion Starter #48
setup 2018
Haven't updated this thread a long time. In the past year i could not race the car so it was time for some new upgrades
I painted the intercooler black to get it more sleeper style. I also installed the new fuel pump, but decided to go with 1200cc injectors, which fit p'n'p with the oem fuel rail.
The EFR 6758 is now equipped with a turbosmart dual port wastegate. Some other parts like a DC2 brake master cylinder with custom stainless steel break lines, a bigger radiator with a slim fan and shroud and some other parts like lower control arms are installed now. The head got fully built, ported and is now equipped with a rocket motorsports cam, valves and retainers. Some parts in the engine bay were replaced with powdercoated ones ... and i cleaned my dc2 recaros the first time after some years
I replaced my 16" ultraleggeras with 15" ATS DTC with beefy Toyo R888Rs. They have the same weight :/ but now i can run semi slicks on the street.
In the next few weeks the new setup is finished and will be mapped. I'm very excited how it will run now
Discussion Starter #49
I also did a "small" wire tuck hiding somes wires and connectors to tidy up the engine bay.
The new d17 valve cover
same
Sex bro!
where did that valve cover come from?
Discussion Starter #55
currently having problems to get the new setup correctly mapped. power is good, but i got many dropouts in the low in mid range.
Tried K-series cop and Audi high performance Coils but still got dropouts.
Running 1300cc flow matched Bosch injectors ... and a walbro 450lph. injector duty cycle is 104% ... shouldn't be with 1300cc on E85. Maybe the injectors are crap and i should try other ones...
Discussion Starter #56
fuel system
We put a lot of work in fixing the problems.
Overworked the complete fuel system:
custom built fuel catch tank, bigger fuel lines, external fuel pump, ID1300cc injectors and fixed the leaking AEM fuel pressure regulator.
After that it was ready for the dyno ...
Discussion Starter #58 (Edited)
now it's official: NEW WORLD RECORD on the d13 engine
Today we've been on the dyno and get very nice results.
>> 520HP on axles @ 29psi
>> 530NM
The engine could do more, but the BorgWarner EFR got it's limit (it's rated to 450hp) ;)
it runs a proECU-K (to d-series!) by Doctronic.at
DYNO RUN: https://youtu.be/pDijfteE7lM
(is there a way to embed the video here?)
I FUCKING CALLED IT!
CONGRATS BROSEF!!
41 - 60 of 66 Posts
