1 - 6 of 6 Posts
L
Any torque specs for bolts bolting up tranny to block?
Lifetime Awesome Member
'89 CRX HF
it would help to put more info like what motor you have and what tranny. in case anyone has a helms on hand. but all the times ive bolted trannys up i never use a torque spec, just tightened them down real good. and ive never once had a problem. but then again most of the ones ive done are domestics, only a few imports
i just use my compressor. no specs here. just make them really good and tight. you should be fine. it's when you get into the engine that you need torque specs cause those things are sensitive to that kinda shit.
1 - 6 of 6 Posts
