1 - 20 of 21 Posts
Dumb question. I picked up an engine stand to work on while i finish my build. I can't find any bolts to get it on there however. What should i use to bolt the engine on the stand while i work on it. Is there something special that i need to be looking for?
Tranny bolts work great. If they are not long enough, take a tranny bolt and match the threads to something longer.
cool, someone who is supposedly into hondas went on about needing special bolts and to contact a honda dealer... i had a feeling it would be tranny bolts, much appreciated.
honda del sol
actually I had bad luck using the trany bolts. I had an f22a6 on my stand utilizing the tranny bolts and when i put it up or started to turn a wrench on the engine, the bolt stripped out and the engine kinda sorta fell. They barely go into the bell housing at all.
What I have been using that works great are the thru-hole engine mount bolts(mount-chasis) with two large nuts(I wouldnt use your personal ones, unless you're into that twisted shit) to take up the extra space and they thread all the way in. resulting in a well attached engine to the stand.
in case the type of stand matters, I've got a big red engine stand that I use.
someone could do a seasch, I've posted pics before......included was my two nuts that I used as spacers.
honda del sol
ah so did you use the engine mount ones before just curious.
I just put my a6 on my stand today, I too used tranny bolts, just the 4th bolt I used an extra long what I think was a suspension bolt to bolt the last point since it was just a hole.
depends on the head design of the stand. One had long standoffs that required longer bolts, other was short standoffs and OEM bolts fit just fine.
See above...
Yeah, it really depends upon the stand itself. I've got an older V8 stand with huge/long mounting points, thus I needed the longer special order bolts from Lowes. Cost more than what I paid for the $20 stand! LOL
95 ex coupe
1 - 20 of 21 Posts
