1 - 9 of 9 Posts
I'm doing a pretty much full build on a d15b7 with a6 head and I'm curious if there's a company that sells a full kit of new bolts for the entire engine. I've been searching the web and haven't found anything.. same with gasket sets, I can't find full rebuild sets only small kits not for a full rebuild. tyia
Meat Popsicle
91 CRX Si
Full bolt kit? What's wrong w the ones you've got?
A lot of those bolts aren't cheap or easy to find aside from the dealership. The only ones you would really need to replace are the head bolts and most convert to studs
I prefer buying new OEM gaskets but there are decent gasket kits on eBay. Lot of people use them and source a OEM HG
98 Civic EX
as for the gasket kit. i got mine from rockauto, full complete oem rebuild kit.
now depending on your build i wouldn't use the intake and exhaust gasket, id go with a performance brand.
1 - 9 of 9 Posts
