1 - 7 of 7 Posts
Friends car is smoking blue smoke when car is first started for about 5 to 10 minutes and then clears up.
The smoke goes away when driving
Any ideas?
Turbo or motor?
Journal bearing turbo with restrictor D16 with vitars and h beam rods.
How much smoke are we talking about here? Just a constant pulsating blue smoke that extends about 6-9 inches out the exhaust and dissipates or one that makes a billowing smoke screen?
more so just a
""Just a constant pulsating blue smoke that extends about 6-9 inches and dissipates ""
could be burning oil until things warm up and expand. and too thin oil. go like 40 wt
how many miles on the head, i had a engine that when it was cold it would seap oil from the valve seals into the head and when started it would burn it out, then after warm up it was fine like ^ said and everything expands
Gunna have to agree with the above posts. Oil is too thin. Id run 10-30 at a minimum, heavier if your in a warmer climate. Actually, IIRC, the Honda manual for the d's calls for 10-30 in temps above 5'C [41'F]
1 - 7 of 7 Posts
