1 - 6 of 6 Posts
EG hatchback
Hi im in the process in installing my blox oil pressure gauge with sensor on my blox oil filter sandwitch plate.
i need help on what wires sensor to route it on the oil pressure sensor. there looks like only one signal from the gauge to the sensor, but
There are two dang looking wire terminals on the oil pressure sensor.
what or where exactly do the signal from the gauge to the sensor exactly specifically goes to. and what second wire goes to the sensor sending unit.
the dang instructions suck....:thinking:
also what would be a good angle for installing the oil pressure sensor on the sandwitch plate.
Ask Blox. Oh, wait, they don't have customer service.
Also, have fun when your sandwich plate leaks or destroys itself.
Thats why it pays to buy a product with support if you arent so sure how to install it. Good call beave.
Retired From Hondas
Usually the sensor is backwards..
black SHOULD be ground.. but its really the sending wire. Ground the white, use the black to the green wire at the gauge.
If it doesnt work, then swap them.
I agree with them ^^, sandwich adaptors usually have issues. It would be best to use the OEM port with a tee.
Remember the port is Bpt not NPT. Dont ask why, it just is.
1 - 6 of 6 Posts
