1 - 20 of 35 Posts
Well, I am a noob to the site, but not Hondas. I know yall like pics and build threads...So I figure I would show off my $40 purchase.....
Here it sits ready to be molested a little,
Here's the hole in the block
The plugs that came out of this motor
Under the valve cover
On the engine stand
Oil strainer clogged with metal, even one of the foot legs was bent
Broken Main Girdle
What use to be a rod cap
Look close and you can see how F'd the crank is
Notice how discolored the bearings are, and the broken girdle
Broken rod and piston has a crack in the side skirt
Rod actually knocked a nice chunk out of the cylinder wall
I will be doing a Vitara build with another motor I purchased the other day. :bigok:
95 ex coupe
well you can count on the block being unusable.
someone decided not to ever change the oil. thats bad.
where did you get this thing?
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
Yeah, I bought it knowingly....Had a full uncut harness on it, along with ALL accessories. I really just bought it to "Practice" on. I wanna build and spec this one on my own. I have done plenty of swaps, just never built anything from scratch. So I picked up another Full Swap z6 yesterday to start building.
95 ex coupe
Acura TL-P
I bought a head from a guy once, got it here, opened the box, and it looked just like that...maybe worse..., the only diff I guess was mine was said to be in good shape. Its on the mockup motor now.
You've got yourself a great practice motor :bigok:
honda/firebird form.
that oil looks like grease.. lazy ass people these days cant even change the oil
95 ex coupe
my boss bought a jeep from a guy and they changed the VC gasket one day at work and i saw in the head and at the point had never personally saw sludge.
walked up to it and was like whats in the head? stuck my finger in it and holy shit it felt like straight mud.
couldnt believe it. and the thing still runs. i think
While we're on the subject of sludge and oil....I found it interesting that all the bearings closest to the oil pump were the ones showing wear signs. The one farthest from the pump looked clean as could be.....Any theories or input on that?
95 ex coupe
Discussion Starter #16
clogged oil passages???
I was thinking along those same lines....But, figured the closer bearings would be less likely to clog. Owell, I have a block I can practice notching, and an oil pump to practice porting on. Are z6 guys still porting oil pumps?
See above...
Yep, if nothing else it's a good paperweight to practice disassembly on. Plus it would appear you have a few good parts off of it...so nice purchase!
92 civic cx hatch
i had one of those heads as well arrive :(
Discussion Starter #20
Stopped by Honda Friday and picked up some gaskets and a couple other little things to start piling in the corner for this build.
1 - 20 of 35 Posts
