1 - 3 of 3 Posts
my lights surged earlier tonight, they went real bright then they all went out. headlights, dash lights except the turn signals and CEL when my shift light comes on, taillights all do not work. my stereo works, the lights on switches for the heater work and the dome light works.
earlier tonight i hooked up a wideband, i wired the power to the cigarette lighter and ground. the wideband still has power.
and since that happened the engine doesn't idle it just stalls. it cranks and starts up and soon as it gets to idle speed it stalls, it runs if it has some throttle, or im driving.
what should i be looking at?
93 Legend L Coupe.
If your lights got very bright, sounds like your alternator is wonky. Get a voltmeter on it while it is running abs make sure it isn't putting out over 14.5V. If it is your regulator has gone bad abs it is tune for a new one.
1 - 3 of 3 Posts
