1 - 12 of 12 Posts
I'm just about ready to build my block but wanted to make sure I'm replacing everything I need to. I've purchased Pistons, rods, bearings. About to order oil pump, timing belt. Is there anything else I should replace on the block? Such as any gaskets or seals or any other thing. Please let me know as I would like to order these items soon.
forgot to put that down, I know I have one somewhere in the garage, just have to find it.
See above...
Yeah, get a complete gasket kit! Hate to see a freshly rebuilt block start to leak because of crappy old gaskets...
would those $50 eBay kits be good? Or do I have to go OEM? Does Honda even sell a complete bottom end gasket kit for a z6?
See above...
OEM is obviously best, but @ $100/120+? When the Ebay complete (block, head, etc) gasket kits are $60-70... I'm going with an Ebay kit once I get my new home and have a garage to do everything in.
Good luck!
okay, thanks for the help. I think I will give the eBay kit a try. Unless, someone has had a horrible experience using them.
See above...
I posted a thread either on here or Turbod16 about a complete I was looking at getting... No one said it was bad or they had a bad experience. i'm sure you'll be fine.
Just use the OEM HG though!
2001 Z3 Coupe 3.0i
Timing belt tensioner & spring, oil jet ring (if needed), new crank bolt, F&R main seals
timing belt tensioner? I was going to get a new belt but didn't realize I needed that also? Is that it must? the kit will come with most of the other seals I think.
1990 Civic Si
id grab a crankcase gasket set it should come with everything you need for the block. and if you are boosting look into some ARP headstuds as well.
im sure you can find a OEM Ishino gasket set from one of the many online oem parts dealers that are far cheaper than the dealer. just look here, im not sure what engine you are building but his set is for a Z6
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=1995&make=HO&model=CVC-SI-003&category=All&part=Crankcase Gasket Set&dp=false
free shipping too!
1 - 12 of 12 Posts
