1 - 20 of 23 Posts
What are you looking to do? D16 is a safe bet though.
97 honda coupe
Im more looking for reliability to proformance ratio, ive heard that the d15 stroke is shorter and the rod bearing journals are smaller compaired to the d16, just overall what would you guys suggest?
Hi, i have a z6 head, im going to be putting on a block, What block should i get for it? a d15 or d16? thanks!
If you can get your hands on a d16 block go for it, it will be better later no matter the reason, stock/reliability, all motor, nitrous, boost. Plus there are tons of tech,parts available for this engine.
If you can, try to get a d16z6 block, 92-95 civic EX or SI.
91 CRX Si
A6 block
97 honda coupe
Well my problem is that im strapped for cash, im actually going to be borrowing money from my parents to pay for this swap >.< What i need to know is it really really that big of a diffrence? a d16 block goes for about x2 as much as a d15 block, and i allready have the z6 head cleaned up and ready to go, all i need now for it is a obd1 dizzy and a b16 throttle body.
the 1.6 will give you more displacement then the 1.5L so it will give you more torque. I also have noticed that the 1.5 block holds up better to heat then the 1.6. But however for the price, and for the performance. Go to the junkyard and get a D16A6 block from a Crx SI or EF hatch si. Get it cleaned and Plained.
97 honda coupe
rods. d16 rods = ~$300, d15 rods = ~$700. mind you this is for aftermarket h-beam rods. this is the biggest difference between the engines that you can't over come.
i would just get some zc rods shotpeened anyways. Allright thanks guys!
i think i might have given you the wrong impression. so just in case here is some info i left out.
d15 rod = 134 mm (not including the jd,, d15b or iirc vx), d16 rod = 137 mm.
also the bearing is bigger in the d16. zc rods would do nothing for you if you have a d15 engine.
yeah, thats what I mean. They are easy to come by, and parts are cheep... so if you blow it up.. no big deal... (unless this is your daily driver...... then you're juiced...lol)
OMG go back to H-T or where ever you came from. no engine is dispensable, reguardless if its you DD or not. there is a finite amount of blocks in the world and soon the d will be just like the b, expensive as hell.
we don't waste a d-series here. we build them and love them. go somewhere else if you are here just to blow them up and not care just cause they are cheap.
88 sedan DX
I think its NEWB years day. Between this guy and the other one....
1 - 20 of 23 Posts
