1 - 9 of 9 Posts
I've had my set up for about 6 months now and i recently blew the turbo (leaking oil past the seals and alot of in and out play). I was told that the turbo failed becasue of it trying to compensate for a boost leak (over-revving the turbo) and the thrust washer shat the bed.
The turbo was a Garrett T3 / T04B "S" trim
TURBO SPECIFICATIONS:
compressor wheel: 48.4 / 69.9 mm 48 "S" Trim
compressor housing: 0.60 a/r T04B
Turbine wheel: 68 trim (stage1)
Turbine housing .48 a/r
Now I have two options. I can rebuild this turbo, and change a few things on it. They want to swap the turbine housing to .63 a/r stg1½ 5 bolts outlet. upgrade the turbine wheel and give me a 360 degree thrust washer, 2 piece thrust collar, bolted down.
or.....
I could upgrade the turbo all together to a Garrett T3 / T4E 57 trim
Specs...
compressor wheel: 56.6 / 74.9 mm 57 trim
compressor housing: T04E 0.70 a/r, 4" / 2½"
Turbine housing .63 a/r
What to do? Any opinion is appreciated
edit:
I also want to add that I made 250 on my vitara set-up. Stock y8 head with a z6 vitara and i-beam block. Now I want to go for 300...I completely forgot to add this haha
Were you using a oil restrictor? And you might as well just get a new turbo since it only seems like a $100 difference.
1 - 9 of 9 Posts
