1 - 13 of 13 Posts
hi, i did a d15b swap in to my cx and its cut out at [email protected] 62000 i need a chip..???
that means dont drive past 126mph. why do you need to go that fast anyway?Are you under the impression that if you go faster than 126 all the red paint is going to fly off your car and uncover the black paint that's really there so your car will finally match the ugly body kit it has?
DAMN 62,000RPM?!
you need a chiped ECU, and its not a good idea to raise revlimits on a stock engine, haev fun with that valve float
x2 on the valve float man consider p-28 ecu and definatly higer rate valve springs or it will be float city,honda put that limit there for a reason and it was not to keep you from breaking the speed limit.:hammer:
1 - 13 of 13 Posts
