1 - 20 of 21 Posts
1999 civic Hatchback
We are pleased to announce that we are now a direct dealer for BWR (Black Works Racing) and we are ready to give D-series.org member very good deals.
BWR has a very neat line of products for you Honda at very affordable price and most of their stuff is backed up with lifetime warranty. Product are made in the USA.
Lets start with suspension products..
BWR Camber kits.
All BWR Camber kits come with a limited 1 year warranty
Lower Control Arms:
Upgrading to the Billet series lower control arm is a ideal investment. Made from high quality billet aluminum precision CNC machined. Bushings are made from high quality polyurethane. These control arms are offered in multiple colors from Billet, Purple, Gold, Red and many more coming soon.
BlackWorks Racing lower control arms are made from forged AL6061 billet aluminum. these are light weight and stronger then the weak factory lower control arms. Our lower control arms come in several different colors, and still allow for the factory sway bar to be used.
WARRANTY:
BlackWorks Racing (BWR) offers a limited 1yr. warranty on all of our lower control arms (LCA's)
Rear Camber Kits:
* BlackWorks Racing rear adjustable camber kits are manufactured from forged AL7075. Each of our kit's use vulcanized rubber bushings. BlackWorks Racing rear camber kits are laser etched, and anodized in two colors (Gunmetal, and Black)
* BlackWorks Racing Rear upper camber arms replace the factory steel upper arms, these are adjustable up to +/- 5 degrees. Using our rear camber arms will allow you to adjust positive and or negative camber in your daily driver or your weekend warrior. By having correct camber will improve tire wear, handling, and safety while at the same time have a lighter and improved cleaner look.
* WARRANTY:
* BlackWorks Racing (BWR) offers a limited 1yr. warranty on all of our camber kits.
Rear Toe Kits:
Rear Subframe.
Blackworks Racing Billet Rear Sub Frame Braces are designed using the latest and state of the art CAD design programs in the industry. Our Sub Frame Brace are manufactured in the USA and made from high quality AL6061-T6 billet aluminum.They will stiffen up your rear end giving your car better steering response and overall rigidity.Each one has a laser engraved logo, and are individually laser serialized number to guarantee authenticity. Includes all the necessary hardware for installation.
Coilover kits:
They have the SS and the GT series Coil over kits.
Features
* The New BWR SS Coilover feature's a wide range of height adjustments without changing the spring compression and sacrificing the shock stroke. Traditional Coilovers requires the movement of the spring perch to determine the ride height, causing a reduction in suspension travel and induce coil spring binding. The bottom shock fork / connector is threaded to allow height adjustments to each drivers need without having to shorten the suspension travel by maintaining the original spring perch location. With this function, each driver can lower the center of gravity to achieve better handling, without sacrificing ride quality.
* BWR SS TYPE SUSPENSION SPECS:
* SS provides height adjustments, damping force not adjustable suspension on the SS version (for dampning force check out the GT series.). Alloy forged aluminum correspondent with anodized finish brackets, spring seats and upper mounts (Some BWR suspension's DO NOT! come with upper mounts.)
* WARRANTY:
* BWR offers a limited 3yr. warranty on all of our coilovers.
* SPRING RATES:
* Front 10KG (560lbs)
* Rear 7KG (392lbs)
Here is a Video of an EG using their SS Coilovers...
John Tran IFO 9.52 @ 161mph
Pretty clean run and as you can see the civic drives really nice and stiff..
And here is a promotional video of their products.. It explains better than what i would...
Blackworks Racing
Accessories:
Forged Lug Nuts (Open end type)
BlackWorks 2" extended open end forged AL7075 magnesium alloy lug nuts are for serious racers, and or your extreme weekend enthusiasts. All lug nuts are hard anodized for strength and durability. For maximum results use our BlackWorks Extended Wheels Studs.
Available for Honda/Acura/Nissan/Toyota/Infiniti/Ford/Lexus
Threat pitch 12 X 1.25 & 12 X 1.50
Black, Gold, Red, Blue, Purple, Tuner Green
Front and Rear Tow hooks
Blackworks Racing Billet Rear Tow Hooks are designed using the latest and state of the art CAD design programs in the industry. Our Tow hooks are manufactured in the USA and made from high quality AL6061-T6 billet aluminum. Laser engraved logo, also includes laser engraved individual serialized number to guarantee authenticity. Includes necessary hardware for installation.
Extended wheel studs
* BlackWorks Racing (BWR) heated-treated 8740 chrome moly wheel studs, are tensile strength of 190,000 psi and are able to easily handle extreme loads and lateral forces found in road/drag racing. BlackWorks racing wheels studs are sold in packs of 16 or 20
* thread size 12X1.5 length 3.25"
* Lug nuts are not included
* WARRANTY:
* BlackWorks Racing (BWR) offers a limited 1yr. warranty on all of our wheel stud kits.
Short Shifters
Single and dual bends..
Drift Handbrakes
BlackWorks Racing (BWR) hydraulic E-Brakes are made from the highest quality materials ensuring the longest product life. These are a necessity for any drift or rally vehicle. You can adjust the position from a easy position handle.
These are universal hydraulic kits!!!!!
WARRANTY:
Engine Components:
Cam gears for Honda D/B/H Series engines
Throttle Bodies..
* BlackWorks Racing (BWR) billet AL6061 throttle bodies are available for the Honda and Acura D, B, H and F series engines. Our newest design features new brass throttle plates to insure no throttle sticking. A stiffer throttle spring and sealed bearings were also added to this new design, by doing that we have gained smoother throttle transactions and quicker throttle responses.
* 4 Bolts, and Throttle body gasket is included in every purchase. Reuses stock sensors and throttle cable. We do how ever recommend our (BWR) TPS sensors.
* WARRANTY:
* BlackWorks Racing (BWR) offers a limited 1yr. warranty on all of our throttle bodies.
LS/VTEC, B20 VTEC Convertion Kit:
- BlackWorks now offers a Full Vtec Conversion kit for people that want to use an LS/VTEC or B20/VTEC set-up.
- BlackWorks is one of the easiest and most complete way to supply oil to the head without any machining required
The kit includes:
1. BlackWorks Vtec Conversion Sandwich Plate with a -6AN fitting for the plate and head.
2. BlackWorks -6AN steel braided teflon hose for oil supply
3. BlackWorks Vtec Conversion Dowels for proper alignment for the head to block without machining
4. BlackWorks 1/8 NPT plug for the oil port in the head
5. BlackWorks worked factory head gasket in 81MM, 84MM size's only. Dowel holes opened for proper installation
this is a " NO Machining kit " we mean that there is no reason that anyone cannot do this kit, with the right tools and skills.
Blackworks Universal Oil Filter Block Adaptor:
Titanium Retainers B/H:
Dual valve springs (B series... D series are Single valve springs)
BWR Billet Oil Caps
No prices? Camber kits and brake handle are interesting...
i want a purple one if they are cheaper then the ASR ones ;)
Shouldnt be a problem.. 92-95 subframe run for $163 (Polished 199)
And we have additional discounts for D-series.org members..
would you be able to do a package with the 22 mm bar and endlinks as well?
Any combination (Brands) in particular?
We sell various brands of Subframes and Saybars. (ASR,BWR,Blox, Progress,SK2, BEAKS.....etc..)
I have one of your hydraulic brake handles. After getting it I believe for the price it should not only come with a reservoir setup. I bought this from someone new that never used it. It doesn't come with a fitting for the wheel
Feed Outlet and im Wondering exactly what kind of fitting it takes. Also why you guys went with a bubble fitting is also beyond me. The reservoir inlet is a normal double flare hole , the outlet isn't?? I don't understand why this wouldn't come with a barb fitting for the res. inlet , and a normal double Flare hole for an outlet.
It looks like a clutch master cylinder to me. From what make of vehicle is the master
Cylinder from you guys use for these?
Hi hater!
Have fun getting an answer noone has seen nor heard from this guy in a very long time...... Sucks about the issue though
1 - 20 of 21 Posts
