1 - 20 of 51 Posts
Hi
im building a turbocharged y7 with a z6 head
Block:
9:1 wiseco pistons
Eagle H-beams
Kms block guard
micro polished crank
new oem oil pump
arp head stud
Head
supertech valves,springs and retainers
aem cam gear
fully ported and polished head
Skunk 2 intake manifold
65mm Throttle body
Im stuck in between zex 59300 cam and bissimoto 1.2 turbo cam
i need your comments
thx
how many big hp bisi setups do you see on here? or anywhere for that matter.
not what you posted. try again.
the guy didnt ask for a whp range that has been reached with either cam. just which cam is better. from those that have the cam, the 1.2 cam is just like stock.
and like i said, i am pretty sure there is a thread somewhere that said it made more power over the zex cam also.
edit: i am looking for the thread/post right now..
Well?
well theres a over 400hp z6 on HT tuned by tempest racing in MD using a 1.2 and theres a few in bisi's dyno vault on the forum in his website. One other thing to consider is price. Theres a decent difference in price and you need to ask if the gains out weigh the cost of getting a bisi
If I had to look at both companies. I'd say bisi, with a 10 sec sohc all motor, is more creditable then a company that makes a nitrous kit and over priced plugs that aren't worth a dam.
Poop Sock
Well put that shit in already! haha I used to hear a lot about bisi and f series engines. When I used to be on gen5alive everyone and their mom used bisi stg 2 and seemed to love it.
well i think ima sell/trade my civic that it would be going in. so I'd end up selling this bisi stg2
alright
we know bisi has a pantload of r&d and he knows his shit. agreed
but zex has been around a while too and they are decently reputable (not as much as bisi )
but the question is... he just said he was stuck actually...never said a spcific question...
anyway with the list he gave us im assuming cost isnt really an issue so i would say contact bisi, tell him your goals and setup and he can create something that will work better than either off the shelf cam you just mentioned
No Tune No Life!
bisi by far for a custom tailored cam.
Bisimoto Engineering
just to let you know zex does not make cam's comp cams makes them. back in the day when zex came into the sport compact game they called them "zex cams" but the same part numbers are now comp cams if you order a new one and all the spec cam be found here COMP Cams® - Cam Spec Card Search
1 - 20 of 51 Posts
