1 - 20 of 73 Posts
1999 civic Hatchback
We are having a special at the online store and Bisi products have a 5% off the regular price.
We are a Bisimoto Dealer so we can get anything on the Bisi's catalog for you guys. So hit us up with your inquiries.
For prices please visit: http://fjdistributors.com/index.php?cPath=89
Bisimoto Cams:
Vtec Cams for All Motor / Boost / Nitrous
D16 Turbo cams: Level 1.2, Level 2.4 for Vtec and non vtec(Non vtec regrinds require sending of Core). Cams take approx 7 business days to be manufactured.
All Motor VTEC Cams: Level 1, 2,3 and Level X
D16 Non Vtec Cams..
For turbo and All Motor (Core is required for the non vtec regrinds) Level 1, Level 1.2 turbo, Level 2, Level 2.4 turbo, Level 3, Level X
BISIMOTO Valvetrain:
D16 vtec and Non Vtec Valve Springs and Ti. Retainers are sold in either a set (Springs and Retainers) or Valve Springs set alone.
BISIMOTO Cam Gears:
For B series, D series, F series, H series and Toyota 4AGE engines
BISIMOTO Drag Wheels
350 Series 13X7---> 7.4lbs Sold in Pairs.. Please contact us
350 Series 13X8---> 8.2lbs Sold In pairs.. Please contact us
350 Series 15X10---> 10.5lbs Sold in Pairs.. Please contact us
350 Series 15X8---> 9.7lbs Sold in Pairs.. Please contact us
350 Series 15X7---> 9.2lbs Sold in Pairs.. Please contact us
350 Series 15X3.5 skinnies---> 7.7lbs Sold in Pairs.. Please contact us
They can be Anodized or Powdercoated in any desired color for an Extra charge. Adds one week processing time for wheel manufacturing.
ADAPTER Plates for tranny convertions:
H2B / F2B adapter plates.
Developed, engineered and manufactured due to popular demand! Unlike the competition, a rigorously tested plug n'play system. Kit comes with signature zinc oxide plated half moon plate, SFI approved aluminum flywheel with serrated heat treated friction plate, custom pillow block mount for half shaft, 8.8 grade bolts, solid dowels, and slave cylinder spacer. No kit on the planet even comes close!
Features:
–Precision machined
–Steel plate signature half-moon design
–Complete, with stage options (with or without EG chassis mounts)
-Custom SFI approved flywheel (no dangerous spacers)
-Flywheel also incorporates timing marks
–Field and race tested
–Design from Bisimoto: drag Honda-Honda adapter plate pioneer, and the Evolution Industries.
Benefits:
–H22/H23/F22/F23 power without the quirky H-based transmission
–Improved power-weight ratio
–Improved aftermarket gearbox support
–Designed to withstand the rigors of racing and street duty
-The only SFI approved kit on the market
–Simplicity
H2D / F2D Adapter Plates:
This is the very same plate system that won the IDRC 2003 all motor champtionships, and showcased in the June to August Sport Compact Car magazine! Many may ask, "Why the D-series transmission?" These transmissions are plentiful and very cost effective. Since many popular Honda chassis come with these transmissions from factory, factory style axles, mounts, shift linkages, and gearbox sensors can economically remain intact. Strength of the individual gears is also a big plus. Unlike their B-series bretheren, D-based gears are "stubby", and take well to abuse.
Favorite transboxes include, but not limited to, the '86 to '89 Acura Integra D16A1, and the '97+ Civic ex (due to the ferrous based shiftforks). The Bisimoto Adapter units, the flywheel, bolts and plate, have been rigorously tested in racing environments for 4 years: a claim which imitators cannot replicate. Metallurgical testing has occured to ensure the perfect components.
Precision is key: misaligned dowels or poor workmanship can result in damaged engines (destroyed main bearings), and gearboxes. This CNC plate system will allow the benefits of power and performance of the H/F variant powerplants without the excessive weight and hassle of the cable-based H-series transmission.
The kit comes with the signature "half moon" adaptor plate, aluminum flywheel, and custom plate bolts. Factory dowel pins and flywheel bolts should be utilized. A 0.5" x 7" strip should be shaved from the block/pan assembly to allow access for the driverside axle shaft. Depending on the chassis frame, use of an aftermarket crank pulley may be required. Many enthusiasts will also be pleased to know that a lighter civic style clutch and civic based axles are used as well.
B2D Adapter Plates coming on the 1st quarter of 2009
BISIMOTO D Series Header.
NEW Version!! Improvements over the old version that will give more power gains and as info goes this header will be A/C Compatible!!
Retail Price is said to be somewhere in the $5 hundreds. Final price TBA later.
They will be manufacturing them in January and we are on the list to get some headers..
Reserve yours today!!!
Honda Civic Coupe
F*ck yeahhh!!!!!
Count me in, Francisco...!!!!
Best regards.-
vtec d16y8. You think you could do a combo deal for all of the above??
Yes we can man..
Give me your city and Zipcode and i will find out how much shipping is to give you a full quote shipped.
Honda Civic Coupe
Hey FJ, i just finish to call Eddie.
All the Bisi' stuff arrived at Buenos Aires in mint condition.
Put me on the list..wanna get my header asap.
Best regards.-
Discussion Starter #18
Glad to hear that..
I will give more info when i get the update from Bisimoto...
1 - 20 of 73 Posts
