1 - 20 of 75 Posts
I have done the mini me conversion and want to know if putting a 60mm throttle body and replacing the 56mm that currently on there will have performance benefits or not really worth doing?
Thanking you in advance.
if you are gettin it for really cheap, cool, if not, its not gonna do shit. until you are boosted/ported head/cams.....the stock intake/throttle body is damn near the best you can have. id just go with a H22 tb...w/e size they are, I know they are cheap...see alot of people using them.
getting it for dirt cheap so you guys reckon its worth getting.Will it add any torque gains at all?
^^^ OMG post number 666 ^^^
whoa dude, thats way uncalled for with the post numer up top. fuck that. matta fact if somone can, delete that damn post for me, or change the number. ha i dont fuck with that, and dude, why the hell u goin rep me with a bunch of 6's wtf.. and it says 667 what u talking about???
Quicker throttle response, just make sure the itm has been ported to match the tb for best results...
Shit, "for best results"?! If you fit bigger TB into manifold that has smaller TB opening, you're hurting your performance VERY badly.
how many over sized throttle body threads are there gonna be with the same answer. no, bigger aint always better.
do this
open your mouth wide open and suck in air (60mm)
now
close your mouth and suck in air (56mm)
which one days it take less time to run out of breath?
do this
now
Wait... doesn't this analogy favor the larger throttle body?
I intend to run a cam in the next month or so so just planning ahead.Which cams are best suited for street racing and everyday use?
Is the stage 3 meant for turbo only?
i ask about that picture that show IM inlet bigger than TB as anti reversion step, is that a good performance if like that setup?
I imagine that it would be better than a port matched throttle body. I'm not sure if the pressure waves would follow the indentations like air would.
Also, what manifold are you using that will support that 64mm diameter cross section? I don't think it has to be that pronounced.
the IM is stock z6's
thats why maybe if we want use bigger tb like 60 mm with stock IM , we should do that missmatch at IM inlet
what about that
1 - 20 of 75 Posts
