1 - 6 of 6 Posts
Well?
both fit the same as long as its a manual.
neither. since you dont know how many manifolds will work for you. the z6, b7, obd2a y8 and obd2b y8 IMs work. they all have downfalls. there is some modification required before install also.
what mods you ask? 3 to 2 wire conversion or the addition of a 96-00 EX auto TB or convert your TB to work (rotor to pull the TB correctly). plugging the air injection set-up if you got a IM with that system on it.
reason for a manual IM? it has the location for the IACV on the back of the manifold. the 96-00 EX auto IM doesnt, as the IACV is part of the TB, like your y7.
IMO: i did the manuel IM with an auto ex TB till i converted to OBD1. far easier then modding the TB. if your like me, i tend to lose small shit when i work, this might be for you. the 2 wire IACV can just sit on the back of the IM unplugged, it will not effect anything.
1 - 6 of 6 Posts
