1 - 20 of 46 Posts
Anyone have any recommendations for the best turbo to use that performs well but isn't too expensive for a stock D16Y8? I will be upgrading the fuel system but other than that, planning on keeping the motor stock. I'd like something that spools relatively quickly, as the earlier I can get into boost, the better. Not looking for a HUGE gain in power, but definitely something to wake up this SOHC.
Also, I will be keeping my A/C, P/S, etc. So hoping it will clear everything, pending the manifold I go with. External wastegate is preferred.
Thanks in advance!
95 civic coupe
Chipped p28,Dsm 450cc, Restrictor box, Dsm Td04 turbo more than enough for what your motor could take
Eg Sedan
Covered many many many times. The above works well. A small t3 super 60 would work, or any t3 turbo for that matter. An eBay turbo WILL work with an oil line restrictor, still could be hit or miss but Godspeed is stepping up their game slowly. Best bet is to find a t3 based name brand turbo and rebuild it. eBay intercooler will do the job just fine as well. eBay wastegate and bov can be rebuilt with name brand parts.
Likely need a log manifold to keep ps/ac, not 100% on this but I know for sure it will allow you to keep both.
Obviously it's best to start with a quality setup, but the budget above has been proven to work but not consistent on longevity.
EDIT: This will be your best bet. Learning to read compressor maps for your own good, that way YOU will be able to find out what will better work for you. http://www.d-series.org/forums/forced-induction/218762-how-turbo-works-how-choose-right-one-you.html
Black/Green Civic HB
Since he's on a stock block and doesn't want a lot of hp, a dsm t25 or even a bigger t25 off a sr20 would be perfect.
Spool between 2-2.5k rpm and would max out a stock block.
A t3 based could work too, but the power window would be shifted up in the rpm.
Retired From Hondas
Yea, but like we all know. Boost is like crack. Leaves you penniless and keeps you wanting more.
The super 60 will spool just fine and leave room to grow to the blocks maximum potential and past that.
+1 on super 60 plus easier manifold flange options
ej8
T28 .48 A/R starts to spool around ~2,500
the only thing is finding a manifold that will fit a t28 and still clear ac.
Most manifolds are for t3 on the civic.
My last step up used a nissan t25 and an edelbrock t28 manifold.Very fun and spooled up quick but that manifold is discontinued and you really cant find it.
Im doing my second setup now and debiting on going t3 or trying to get a slim adapter plate to go t28
ask me how I know lol
I always wanted to try a disco potato on a stock d16.
I bought (2) TD04's from a Twin Turbo 3000GT VR4 and god those things are tiny. Would of been fun to put one of them on a D16 and watch it spool up.
I've seen people put them on Honda Ruckus's :scooter:
Yeah the manifold i had was just the one off of ebay, I'm sure i could've retained my AC still but who needs that anyways :blue:
I actually might be switching back to my disco potato since my 60 trim takes like 3 hours to spool up :death:
'92 CX Twincharged D
I like my HE351ve, but it is huge and give very little room for a/c and p/s.
I barely have room for my hood to close witth SC14 supercharger in the mix.
I have not seen a GT28R used on a d16, like to.
Using a 60 trim, I would think a little two step ignition would help with spool time.
ej8
you must not live in Tx.
When my ac broke it was hell.
Then i turbo and the ac wouldnt work on the streets due to the slim fan not cooling enough. I switch to a oem fan and it work but summer ended.
and thats what i dont want is a slow spool. I like the t25 setup i had full boost fast and it pulled hard.
95 civic coupe
This was my first first set-up almost like what i mentioned above, except the turbo is off of a Mazdaspeed 3 which is the K04 that Audi S3 also uses. Stock D16 and with a nice street tune it kept running 13s on steelies.
We used a Hf manifold with a custom adapter plate to run the turbo
Here's a thread of the build just in case it will help
http://www.d-series.org/forums/forced-induction/161200-my-friends-set-up-we-installed-today-k04-z6.html
Boost pressure is present around 2.5k and full boost at 3.8k I rocked this set-up for about a year or so before taking it apart and built the motor. I've also ran small t3 ebay turbos much simpler set-up with t3 flange ram horn etc...
Jvtec I did basically the same thing with my first setup...i used a 3/8 plate, drilled all the holes for the he manifold and t3 flange, then welded the bolts into the plate and ground them flat.
wasn't great, but was cheap and worked.
Discussion Starter #19
If I go with a T3 flanged manifold that'll clear AC, what do you guys think of this turbo?
If it is no good, let me know. for $150, I would be tempted to take my chances???
If I go a T25 turbo route, looks like most if not all are internal wastegate. Best just to get any manifold that will fit A/C and then block off the external wastegate port?
Great responses so far. Keep 'em coming.
ej8
Amazon.com: CXRacing-T3 T4 T04E Turbocharger .50 AR Compressor .63 AR Turbine 5 Bolt: Automotive
That's your stander eBay turbo. It will work, just needs a oil resectior.
And for t25/t28 your need a adapter plate. Which can cause problems depending on which manifold you use.
If you can find a t25 manifold then all is pretty good. And yes you can just block off the wastegate hole. They sell plates for this normally about $25.
The best thing to do tho is look at other peoples build and see what they did to get it all working.
But you can use
The cast iron manifold version 2
EBay t3 turbo.
A custom made downpipe 2.25 or 2.5 and it will clear ac easily.
Then get a wastegate and do open dump for less welding/fab work.
Or route it back into the downpipe for a quieter car.
Make sure you heat wrap all you can. And your have a turbo civic with ac.
1 - 20 of 46 Posts
