1 - 6 of 6 Posts
93 civic cx cdm
what do u think is best between:
-rustoleum reformer (rust converter)
-rustoleum primer paint (not sure if converter or only protection)
-corroseal converter/primer/paint
-por15 (not a converter but more like an innihbitor of air so rust stops and blocks further rust from occuring)
or do you have another type in mind?
thanks!
eastwood coatings.
i used it on the inside of my jeep wranglers frame.
super super impressed. the outside is just hit with rustoleum, but the inside is what matters.
stratton.
get the shit that stops it from being rust. then prime it. then paint it.....why make it harder than it needs to be?
as with any anti-rust project, physcially remove current rust, then use an inhibitor-primer combo
then you can seal it with good paint or another layer of primer, then whatever paint you want.
dont ever just cover it up with a converter. it will still rust beneath it if you do this
1 - 6 of 6 Posts
