1 - 10 of 10 Posts
before adding your 2 cents, care to explain WHY you think it is the best?
Gearing is wrong for anything performance related.
only cheap upgrade for the 92+ EX trannys, CRX 4th gear (.9375) vs. the stock (.909).........
Needs grinding to fit though :)
88 ED6
hatchkid96 said:
best bet would be just an ex tranny. its the same as an si excluding the 5th gear. ex=.75....si=.702 (ex=better gas milage in 5th)
Its the other way around; the .702 will get better mileage.
1 - 10 of 10 Posts
