1 - 2 of 2 Posts
K
whats up -
just wondering everyone's opinions on which head gasket to use for my y7/y8 mini-me.
i've heard that the D16Z6 head gasket is thicker....and will result in a different compression ratio (CR) than using the Y8 head gasket which is thinner and results in a slightly higher CR?!
is this true? which is better to use? will the comp. ratio even change that much?
if i go with a cometic gasket, what size bore will i need? (stock y7 block)
thanks.
1 - 2 of 2 Posts
