1 - 20 of 23 Posts
96 civic
I am rebuilding my d16y8 for boost this summer and as always I will only be putting the best in my engine. Neglecting cost, what would be the best forged piston/rod combination in your opinion?
Neglecting cost?
Crower rods, CP pistons would be a solid bet.
Though people have made plenty of horsepower on a lot cheaper stuff, with good reliability.
1993 Cobra
srp and eagle --- good solid combo, not very expensive too.
Lifetime Awesome Member
'89 CRX HF
Eagle rods are good for well over 600hp, there really is no reason to spend more money for Crowers.
Wiseco/CP/Arias are all great slugs if you don't mind spending money. I run SRPs, and they work great for me.
Meat Popsicle
91 CRX Si
Don't all the aftermarket rods require notching the block? If so, I would think Eagles would be the only choice given their price and strength..
96 civic
Discussion Starter · #12 · (Edited)
Are you running a sleeved block?
yes i will be sleeving the block, plan to run a good amount of boost.
well i just did a quick price check for eagle and crower rods. i found eagle for about 350 and a crower set for over 750. if theyre both forged and appear to be about the same thickness, then i dont understand how the prices can be that different. i dont think that the crowers could really be twice as strong as eagle (could be wrong). anways, if the eagle h-rods are supposed to be good up to 600 hp then i think that will do it for me.
any more advise on the pistons?
I mean if your only going for 400hp, which are the high side of 90% of the builds in this forum, then just look around on the threads; I'm sure you will see a combo of srp and vitaras. I personally am running vitaras because they are cheaper and meet my goals.
i can count the number of 400whp vitara builds on this site with one hand. its even easier if you disregard setups that never preformed at the track.
what ever happened to that thread where i made the call out? i forgot about that!
'89 CRX HF
400hp in general for a d-series is more of an internet legend than anything. There are a handful of people that have actually done it, and a shitton of "400hp build" threads that never even come close.
See above...
Do jink me! LOL Me and two others in the local area have this as our goal. So we all hope to reach it on E85.
96 civic
Discussion Starter · #18 · (Edited)
I understand, it's just a goal. May or may not reach it, but at least my engine will be a lot faster either way
My civic
I'm running an Eagle/Vitara Setup with 75.5mm Pistons and I've got 20k miles on my block on 12 psi.
I'm shooting for 350 WHP, daily driven.
My tuner had 433 WHP using the Eagle/Vitara setup and drove it 30k miles and had not one problem.
cp or wiseco would be my preferred choice. im starting a build as well and i ended up getting eagle rods along with cp pistons
1 - 20 of 23 Posts
