1 - 20 of 27 Posts
I don't know how many companies nowadays produce a good turbo manifold that's compatible with both AC and PS. I'm not looking for a pre-fabbed kit like Greddy, Revhard, etc. And when I mean best/good I'm talking fitment and quality wise.
Looking for something that fits what I'm looking for.
same
custom built. nuff said.
Then the other only option is like a custom turbo manifold?
:wacko:
Sl2,Cx Hatch
many companys make Many options that will let you keep Ac/power stearing. Ask local fourm vendor Or ask the GOOGLE i am sure that will show you some more. Good luck
I guess I'll them out. Thanks.
1999 EJ8
x2
A solid manifold that will give you the clearance you want, quick spool, and best of all: cheap.
That is pretty cheap, I wonder how those compare to log manifolds.
top mount manifolds save ac and ps, but can cause other fitment issues
your best bet is to READ the ebay auction description
there are a few log style manifolds that are offset towards the tranny to clear the a/c, but most small turbos will claer just fine and require perhaps a turbo sock to be on the safe side
turbo ftw
Discussion Starter #14 (Edited)
turbo ftw
I've always owned cars without AC and PS. Since you said that most small turbos will be fine. What's the biggest turbo I can run then? Looking to max out at 300-350whp.
Discussion Starter #18
Its better than a log manifold and is proven to over 400 hp
Also, I beleive you can get it in cast stainless, which looks just as nice as a tubular imo
I wonder with the cast manifold I can run a T3T4 50 Trim and still retain AC with that turbo.
between a ramhorn and log, its not a huge difference in power ability
spool time is the biggest factor.
seriously, search for ac compatable manifolds in google, you WILL find plenty for less then 300 bucks
1 - 20 of 27 Posts
