1 - 7 of 7 Posts
Boost Gets You Laid
Del Sol
I guess you can call it a positive camber issue. (88 CRX DX)
The top of the wheel tilts away from the car.
Dude said he a curb but nothing looks bent suspension wise.
If the LCA was bent would that make the wheel sit out the way it's doing now?
I'll try to get some pics. I don't want to throw an excessive ammount of cash at this issue.
Asshole
Dude be careful when dealing with front suspension damage. The dc/eh2 that we picked up had an issue with the front (which was the reason why the dc front was swapped on in the first place). The fix was a whole new crossmember. Its not easy to tell if the corssmember is bent. If the lca doesnt look bent, the shock/spring or the camber plate doesnt either, its not easy to tell by looking, but the crossmember could be done with.
Boost Gets You Laid
Del Sol
Discussion Starter · #7 ·
Body is straight, I popped in another steering knuckle and it was straight.
Too bad the knuckle was from a HF and I have a DX. DX has more splines on the axel so I'll grab a DX knuckle from Maryland this weekend :TU:
Thanks for the other helpful suggestions guys :TU:
1 - 7 of 7 Posts
