When belts start to squeak does it mean that its going?
I took a look at them, and they dont seem so bad, but it seems to only squeak in the morning when I start the car up cold. I've tried spraying belt dressing on them, but only seemed to quiet them down for a few days.
Also, how hard is it to change all the fan/accessory belts?
appreciate any help.
thanx
JDM Justin
95 del Sol
try tightening them first before you replace them.
i.e: my alternator belt was squeaking something feirce. i unbolted my alternator, tightened it. squeaking went away.
just a thought...
J
just a thought...
J
What is the process involved in tightening the alternator belt? Is there a tensioning bolt on the alternator?
thanx guys
JDM Justin
95 del Sol
you just have to adjust your alternator belt until it's tight.
1. loosen the bolts on your alternator
2. use a crowbar or long screwdriver for leverage to move the alternator
3. check the belt tension
4. if it's tight, torque down the alternator w/ the leverage still applied
that should be all
NOTE: don't get it too tight...you need a lil bit of movement
this was done on my d16y7
if i'm wrong someone quote me, please or if there is a different way to do it
