1 - 1 of 1 Posts
I may be correct in my thinking or I could be way off which is why I turn to you guys. I have several blocks and cranks lying around some of which are original to each other and some that are not.
My question is will the color chart for bearings still hold true? I'm kinda thinking yes
Lets say you have a block with AAAAA and a crank with 11111
that equals out to all red
Now lets take the same block and use a dif crank. Block AAAAA Crank 22222
which equals to all pink
My thoughts are the letters are describing the bore of the block and the numbers the circumferential size of the journal. So in actuality nothing changes.
Does this sound right?
Edit: to help clarify these are all A6 blocks with A6 cranks.
1 - 1 of 1 Posts
