1 - 18 of 18 Posts
Just a couple days ago I noticed that my battery light flickers ocassionally. I havent noticed the lights dim or anything. I check the battery voltage at idle with all the accesories on and I got 14.34 volts. The battery connections are tight. Im not sure how much deflection the alternator belt should have, but it doesnt seem super loose. I could tighten it a little. What else could I check?
same
You may have a short in the wiring to the dash. Check for breaks or corroded connectors.
same
4 years huh. Time to get it checked
Oddly the "Battery" light has nothing to do with the battery, it is a circuit in the alternator. Alternator needs load tested (with amp reading)
same
Do that and report back
Doesn't have to come off the car, just needs tested with a load.
same
If the belt is slipping the ya I could see that being an issue.
same
Sounds like you might have nipped it.
1 - 18 of 18 Posts
