1 - 20 of 56 Posts
Acura TL-P
52MM (550hp .55 a/r) 59MM (650hp) , 62MM (750hp) and 64MM BEP Batmowheel turbos in stock!
T3 .70 a/r
Contact us for DSO special pricing.
Pretty cool!
This is the kind of stuff that is making new turbochargers perform better and better than old turbos of the same size.
Same as above
I did a little googling and found this:
Bulleye Power BatMoWheel
Id like to see a compressor map comparison between this and one of their normal billet wheels.
lol 804rwhp with the gt42 @27-28psi vs 941rwp with S374 @30psi
yeah it's only 2-3psi difference but if you're comparing wouldn't you keep the boost the same?
'97 crv
but it made about 140 more hp on 2 psi. Granted, not a very good comparison, but still, dam
Yah, objectively you would need a lot of runs on the same car with the only difference being the wheel. Same compressor housing , same boost, and tuned for the same AFR (assuming it would be running speed density and is needed).
Then, compare torque , spool, and IAT.
Nice looking turbos but bloopbitybop-ghostdad are they expensive!
Acura TL-P
They are also comparing a wheel that is 2MM smaller there. A smaller wheel making nearly 140 more whp at 2-3 more psi is more than substantial.
MuthaFuckaUppa
2009 Civic Si Sedan
Batmowheel looks great. Jet turbines have been making their entry turbine blades like this for a while now. More surface area on the leading edge grabs more air.
Acura TL-P
Discussion Starter #20
Here is a 66MM Batmowheel next to a 72MM Bisi/Hurricane Turbonetics
A good sample of wheel design next to a standard cast wheel
1 - 20 of 56 Posts
