1 - 7 of 7 Posts
I took apart the bottom end of my y7, guess what I saw? The bearings on rod 4 lower end were protruding out as if they were smashed. There is also no guide lip to slip into the rod groove OMFG I'm thinkin what did this past owner do. Then I check piston 1 bottom it has small grooves but no oil hole.... Both pistons were traveling up and down. I need suggestions on the best bearings possable. A link would be great. I have never had to do bearings before.
The rods and crank look fine with no grinds or grooves. I do have the new eagles headed my way but bearings are now my issue. Any help would be great. I'll post pics this eve.
D-Series Destruction Master
I'd have the crank and rods inspected before doing any further work on it. No use rebuilding something that can potentially fuck up right away.
1 - 7 of 7 Posts
