1 - 10 of 10 Posts
ughhhh this is really annoying me! I still cant fix this idling issue I have. i got a jdm d15b in my crx. the car idles perfect up until it get to operating temp. then i have a surging idle. 600rpm- 1200rpm I bought a brand new $150 IACV and it still does it. cleaned my fitv, checked vacuum hoses. I cant figure this out. I noticed when i turn my lights on, or turn the heat on it will idle fine..
also i noticed when i unplug my iacv it idles fine..
i donno what to do..
tiny vacuum leak somewhere or TB blade is dirty or adjusted too far open.
That screw that your NOT supposed to mess with.......yeah don't!
TPS + random ghetto adjustment = idle problems.
op: i hope this is the only case in your engine. then the fix will be simple.. use a multitester to calibrate it.
Yeah like Bone said, that yellow paint was there for a reason lol
d-series Member
tps doesnt cause a surging idle like op describes... it will cause a low idle or high idle and funky acceleration characteristics while driving, but no surge. before i fixed it, mine was less than half the voltage measurements it should have been haha
Granny Wagon
don't tink he means surge per-say. think he just means the idle is hunting up and down? anyway, doesn't hurt to check the basics anyway. eliminate a few possibilities. also was the car mapped?? were the idle characteristics mapped on ok?
thats for the replys. Ill check the tps tomorrow.. but i dont think thats the problem. Like i said. It only does this when its warmup fully. idle go from 500rpm, to 1200rpm at a steady pace. over and over and over. I drove my to buddys house to see if he had any idea.. I just let it idle like that and after about 30 seconds it idled normal. then i revved it a couple times and it idled perfect. I let it idle for a few minutes and revved it every once in a while and it still idled perfect. But then i got in the car, put it in gear backed the car up about 10 feet and it started idled from 500 to 1200 again.. over and over and over at a steady pace.. then let the car idle for about 5 minutes again and after about 30 seconds it would idle fine. but as soon as i begin driving it the idle will go all weird again... this is sooooo confusing!
Granny Wagon
i'm not lying when i say the symptoms are IDENTICAL to what my buddy's evo IV was like. his TPS was just out by a fraction, barely needed to touch the thing to adjust it proper. just so you know...
88' honda civic
You said you CLEANED the FICV but did you adjust it????
my buddy is coming over tomorrow with his volt meter.. i dont have one.
and ya i screwed the ficv valve thinger futher in. it didnt do much.
1 - 10 of 10 Posts
