1 - 10 of 10 Posts
90 CRX Si
Guys i've been having a problem lately of bad gas mileage. Its been as low as ~20mpg over a tank, and no higher than 28-29 and that was all highway. Usually my car makes in the mid 30's, high 30's on highway trips.
Fuel filter is recently changed, plugs and oil about 3 weeks ago (old plugs looked ok, just had carbon buildup on the outer metal like the threads), my A/FR's seem normal on my LC1, WOT is around 13:1 all the way across and cruise is between 13.5:1 under load to 16:1 in very light load.
I don't smell any gas, and I can't find any leaks under the hood, BUT I am losing pressure rather quickly once I key the car on w/o starting it. Its a stock pump, RC 320 injectors, and AEM FPR on stock rail. B&M pressure gauge on the filter is where I'm seeing pressure fall from 45 to 20 within 10-15 seconds, then slows.
90 CRX Si
:oops: Yeah I've had a walbro 255 hp laying around for quite some time, i just haven't put it in. I know the pump could cause the pressure to drop, but what about the mileage. It does kinda feel like I have to keep my foot in it a bit more than before, especially at lower RPM's
92 cx
Well youd get bad mileage if your pump wasnt pumpin enough pressure when u put the throttle down, kinda like a leaky fuel injector or bad injector would also give u bad mileage.
90 CRX Si
That's what I was thinking, but i figured it would lean out the AFR's and I'd be able to see it on my wideband. If anything, it may be a bit richer than it used to be.
92 cx
Maybe if u got free time go under the car check ur fuel lines make sure none of them are pinched from random chit. Other than that im bad with electronics. Good luck.
90 CRX Si
Its called get that loan and build the motor lol,Change out that pump i bet that will help.How long you say it has been going on for?
I know, i keep going back and forth on whether or not I should do it. Anywho, its been going on for probably about 2 months
Oh and BTW, my compression is down a bit from 4 months ago, it was
#1 - 203
#2 - 202
#3 - 205
#4 - 205
This was right after i almost killed it by sucking up some water.
Now its
#1 - 203
#2 - 190
#3 - 190
#4 - 205
1 - 10 of 10 Posts
