1 - 4 of 4 Posts
96 EX Coupe
Hey guys so I’ve recently boosted my little d16 and the thing is amazing how ever I recently started getting a bad vibration. At around 3 grand the entire car is vibrating not shaking. There’s no miss fire or anything, air fuels read normal. I ordered a light weight black path racing harmonic balancer and was wondering if that could be causing the vibration. And the car can be moving or stopped it vibrates any time the motor goes to 3k wheter in neutral or in gear.
make sure you installed that pulley correctly.
If aluminum, you will need to loosen it and re-torque it to around 120-140 LBs. I think hodnas method is somewhere around 80-90 LBS then a 90 degree tighten.
Id recommend looking up honda's method on crank pulley install and go form there.
3k rpm does not sound normal, and usually points to something loose, or like EF above said, exhaust smacking something.
1 - 4 of 4 Posts
