1 - 12 of 12 Posts
08 H-D Ultra Classic
Why so many threads?
ministry of mayhem!
93 honda integra
that sound could be anything.
post a sound clip.
95 civic coupe
Hopefully not your valves
doubt it would bend valves. Did you adjust your valves properly on your rebuild? or could it be your VTEC lifters (can't remember the proper name right now) causing noise?
Run the car without the valve cover on, just take some cardboard around the outsides to keep the oil splash down and look/listen. Carefully use a steth or screwdriver and listen all around until you can track down the noisy area.
1 - 12 of 12 Posts
