1 - 19 of 19 Posts
Accord
well i sent my head out to my boy Jason & staff @ WHITFIELD for some resurfacing, dont plan to build it til it breaks. that's just me! also I cleaned up my block, w/ some micro-polishing ;) lemme know what ya think, i did the head to but doesnt look as hawt but it looks good!
HERES SOME BE4 SHOTS:
THEN SOME IN BETWEEN:
very nice very very very nice. Did you use wd40 and a polishing wheel? Looks good either way!
Worst Mechanic Ever!
EG
Bling bling, ya'll!~
Accord
Wow that's the first i ve heard of it that way, I used a secret polisher I have....hehe and a wire brush
Accord
The latest & greatest to help ease the starin on some parts @ 10 psi!
ARP flywheel bolts (old ones stripped from previous idiot)
ARP Headstuds ( I dont want no stinkin' lift)
Kms Block Gaurd (gotta hold them sleeves 2gether)
Accord
Discussion Starter #15 (Edited)
here are some pics of the BG finally installed! (labor provided by: My buddy)
Brief blockgaurd how to:
Install time 10 min.
skill level: B
Tools: Rubber mallet/ dead blow, Dowel pin
Set the gaurd evenly/square onto the block, gently press it down by hand to get a rough idea of fitment....
USING A RUBBER MALLET (RUBBER DEADBLOW)gently begin to tap it in from the center out (cyl. 2, 3, 1, 4) until it lays flush with the block
If you are not skilled i dont advise this part w/ the following tools you may see.....( unskilled pls. prepare: wire hanger [if you go too far], a dowel pin larger than cooling wholes, and a priest w/ some holy water!!)
In the same fashion begin to tap the gaurd gently down w/ dowel (in my case philips screw driver) until desired depth is reached 1.5mm - 2mm. must be either or depth, even all the way around, not 1.5 here & 2 there!
FINISHED PROD.FINALLY REMOVE ALL DEBRIS
1 - 19 of 19 Posts
