93 Civic del Sol Si
Ok, so I read somewhere that a b7 block with a y7 head will not work because the b7 does not have the crank positioning sensor. Is this true?? What does the y7 head have to do with the crank positioning sensor??
If this is true... I'm gonna be pissed haha.
what year car and what ecu are you using??
93 Civic del Sol Si
use your b7 dizzy since the cps is in the dizzy and 1.5 timing belt with b7 cam gear :TU:
1.5 timing belt is to long, and I have an AEM Tru-Time cam gear I'm using instead. But thanks for the advice on the dizzy, I was going to use it anyways.
