1 - 6 of 6 Posts
As some of you know my z6 bottom end is almost done but I am still minus one head. I searched and couldnt find anything after 11 pages so Im here to get some opinions.
Should I buy a z6 head or use the b7 head that I have on my stock engine.
Im leaning more towards the b7 head if possible so I dont have to shell out cash on a head but I have a few questions that will tell me whether or not this will work.
1. Will a b7 head on a z6 block change the compression?
2. What timing belt, headgasket should I run with this combo?
3. Will I still be able to run a 92 si ecu(p28 I think) or will I have to run a different ecu?
4. Will the supertech z6 valves, springs, and retainers work on the b7 head?
If its to much of a hassel Ill just get a z6 head and be done with it but if its simple and has aftermarket parts then Ill run the b7
Thanks guys, rep to those who help me out.
I can't read...
1. Yes
2. b7 timing belt, z6 head gasket
3. No, you would throw a code because of the vtec
4.No, the z6 and the b7 are of different castings, but i've never tried it so maybe.
personally i would just go with a z6 head and save yourself the headache...
I figured but thought id ask
z6 head it is thanks man need to spread rep before I can give it to you.
sub-sponsor
93 civic
1. Yes
2. b7 timing belt, z6 head gasket think you could use a z6 timing belt or a a6 as well
3. No, you would throw a code because of the vtec unless vtec is disabled im running p28 maps with no vtec
1 - 6 of 6 Posts
