1 - 11 of 11 Posts
civic lol
ok so im using a d15b7 distributor on a d16z6 head. My question is should it work the same or close to the same as the z6 dizzy???revvs and idles normal...
If you can get it timed right, it should be fine.
I have a b7 distributor on a b7/z6 mini-me, and I had to cut off one of the ears and take a lot of material off another. I put a spacer and a plate on one of the bolts because there was so little material below the bolt head. It's not pretty, but it's been fine for almost 20k miles.
civic lol
Will a bracket hold it up well instead? If not then wats a good way to install it a?
civic lol
My friends dad is gonna put a bracket to hold it but he not sure if it will hold well..I wanna no anyways that's have been tried and had good results?so I can tell the Guy how and what to install it?
1 - 11 of 11 Posts
