1 - 11 of 11 Posts
okay first post on here... hi! :)
me and a few friends are undergoing a budget turbo build. we have most of the parts for the turbo but were going to rebuild the bottom end, which is where we have the questions...
we have a d15b7 engine, yeah blah why bother, but we are.
we are going to use eagle rods,
We have a z6 head, and a b7 head, and 2 others that i will get back to you on.
~were going to replace, the rods, pistons(optional), cam?,
i guess what were trying to say is how do we wield 300hp to a d15b7?
with a tdo5h turbo.
and where in gods name do we find these parts? i look everywhere and cant find jack shit... thanks :)
eagle doesn't make rods for the D15's
Honda City
ej1
$$$ CROWER RODS $$$
Or cryo'd thicker than d16 d15a2 rods. Same length and sized ends as stock b7 rods.
You could order the $320.00 136.4mm vitara h-beam b7 rods with steel bolts from hungry but good luck.
They call me Awesome!
but the do make them for d16, which fit the b7 crank correct? or am i just way off?
ABSOLUTELY NOT!!!!! (as previously stated). The only cheap (ish) rods for a D15 are going to be the FJ custom rods.
Easiest way to reach 300hp is to buy a Z6 and build it with Eagle rods/Vitara pistons.
Honestly, it sounds like you need to do a lot of searching and learning before you take anything apart!
Discussion Starter · #8 ·
isnt that what a forum is for?:???:
im not the civic enthusiast, i work on chevy blocks:usa:, im just trying to find out some info before i DO tear it apart.
plus we decided to scrap the d15 and get a cheap d16
ej1
You could have at least sold it on craigs list with a good crank.
95 CX Hatch
Wait another month or two. The fj rods for the usdm b7/8/2 are out and in the testing phase. They WILL be available very shortly :)
1 - 11 of 11 Posts
