1 - 20 of 43 Posts
1995 Honda Civic Lx
so heres the before pictures taken on 4/08/2011
04/14/11
Cylinder Head
Above^ is Exhaust Side
Below\/ is Intake Manifold Side
1995 Honda Civic Lx
i got my oil and water pump just need to buy the seals and put them on also purchaseing oem piston rings
1995 Honda Civic Lx
ARP GSR STUDS,HONDATA IM GASKET,OEM B20Z2 HEADGASKET,GOLDEN EAGLE DOWEL PINS NOW JUST NEED VTEC CONVERSION KIT
1995 Honda Civic Lx
And then!!!
i did run into problems because i was a noob at building the engine i didnt bother plastigauging and the bearings spun! so i had to redo everything! and before that in hand it was leaking oil like crazy again because i didnt tighten the head down correctly!:rant2:
But you learn from your mistakes and learn to never ever do it again! lol heres what the first sign i ran into after the amazing pig squeling noise! i couldnt figure out the problem for a while:willy_nilly:
After i returned from my trip to vegas i decided to start tearing it apart
1995 Honda Civic Lx
Soooooo i took out piston #4 i didnt find any bad scoring on the piston nor on the cylinder wall,but one of my rings were slightly more open than the other so i replaced it hopefully i get my comrpession back but as to checking the main bearings i came across this :/
HOLY GUACAMOLY BATMAN THOSE main bearings were DONE!
During this time i had another b18b1 crank laying around in my garage yes they are exactly the for those who were wondering i did reserach same part number
so i went ahead and got the other crank repolished
Before
After
Before
i used tal-strip paint remover
but i did sand it down regardless 400,600,800,1000.
Masking
High Heat Primer 3Coats
1995 Honda Civic Lx
The Rebuild Of the Rebuild!
The start!
I removed oil pan,oil pick up and girdle.
Removing Main caps and rod caps(Also removed Main seal and oil pump of course)
Bare block almost!
1995 Honda Civic Lx
PLASTIGAUGEING THE BEARINGS >.<bearings in order from 1,2,3,4,5. Were Okay!!
And now torque to specs
1st:18ft/lbs
2nd: 56ft/lbs
vvvv
1995 Honda Civic Lx
Mocking up!
This actually took place last weekend it took almost a whole week to fine tune it and get it running properly the timing kept slipping on me so i had to go step by step in order to get it done right:TU:
and here she is :) completely redone!
1995 Honda Civic Lx
Clean build man, i didn't know you could use a b18 crank in a b20.
yeah i didnt think so ethier but you can:TU:
they are the same part#s
very nice!
i would recommend either a gsr or z10 block girdle.. will allow you to rev your motor up more reliably.
will do man thanks for the input
i was wondering why i didnt have one but im pretty sure if i do get the gsr one i might have to get a baffeld oil pan?
or will it be able to clear it?
1992 Civic CX HB
b18/b20b/z crank have the same 89mm stroke
the b20 gets its larger displacement from the 84mm bore vs the b18's 81mm bore.
the b20a from the prelude uses an 81mm bore with 92mm stroke
very nice build!
one of these:
1992 Civic CX HB
transferred my earlier post to the previous post.. it was stuck in with a ton of pics around it LOL.. didnt realize you replied to it till i re read your post.
and yes you'll need a GSR windage tray and i think i might have a gsr oil pan too.. will have to check.
B18C1 pan
B18C1 windage tray
B18C1 strainer (oil pump pickup)
B18C1 main bolts for the center 3 caps or an ARP main stud set for a B18C1.
Not worth it IMO unless you road race a lot and run it at high RPM for extended periods of time.
B20VTAK is weak son!
:biggrin:
1 - 20 of 43 Posts
