1 - 7 of 7 Posts
C
I want to put a b20 or crv crank gear on my d16z6 to get more boost.
Is it possible or does someone make one for the d that is larger.
N
Crank gear? Do you mean harmonic balancer? If the pulley is bigger than you will get less boost. If the pulley is smaller you will get more boost.
C
I thought if the crank gear was bigger it would spin the supercharger gear faster. In return this would create more boost.
C
then how do the b-series guys get more boost by adding a b20 crank gear.
civic4ges is NOT SMART!!!!!!!!!!!!
Bigger crank pulley spins the SC pulley faster, thus creating more boost.
crazysol is correct.
A smaller pulley on the SC would create the effect Civic4ges speaks of.
Simple gearing, be it gear drive or belt drive.
Cool User Title Here
Bite me bitch...I was thinking the opposite, as I always do with retarded and advanced timing
1 - 7 of 7 Posts
