1 - 6 of 6 Posts
Anybody know if the B16A2 and B18C (Type R one) have the same throttle body gasket?
IIRC the 62mm tb comes on the B18C GSR spec. but its got the gay reveres pull, which can easily be fixed by swapping a regular pull from another honda TB.
there might be a 62mm on a JDM GSR engine, but i doubt it. based off hondas use of the 60mm TB, pretty sure they only went out of there way for a bigger one on the type-r.
pissedoffsol said:
Honda Throttle Body Sizing Chart
Inside Diameters (in mm)
  • d15b7 - 56
  • d16a6 - 55
  • d16y7 - 56
  • d16y8 - 56
  • d16z6 - 56
  • ZC - 55
  • d16a1 - 55
  • d16a8 - 55
  • b18c1 - 60
  • b18c5 - 62
  • b18a - 58
  • b18b - 60
  • b16a SiR - 58
  • b16a Sir2 - 60
  • b16a2 - 60
  • b16a3 - 60
  • b20b - 60
  • b20z - 60
  • h22a - 60
  • h23a - 60
  • f20c - 62
  • f22 - 60
  • f23 - 60
on this list, only 62mm stock ones were on the type-r and the s2k. though, it might be wrong.
I was always under the impression that the B18C-R was the only engine with a 62mm throttle body, but I'm an impressionable biff, so I may well be incorrect.
Think I shall order a B16 TB gasket and see if that fits as I can't find the part number for a B18C-R one.
Damn typing is hard when you're wasted!
1 - 6 of 6 Posts
