1 - 9 of 9 Posts
I have the stock p75 ecu and a 97 obd2 b18b.
the dizzy on the b18 is obd1,
what do i need to convert everything and use it in my civic,which is obdo?
using the stock harness,i need a obd1 to obd0 convertor from dizzy to> harness...WHERE DO I GET THIS?
and i need a obd0 to obd1 converor harness to ecu
right?
93 integra ls b18c
guessing you have a ef going from obd0 to obd1
for the dizzy could always depin and repin the obd0 connector on, or
HONDA ACURA DISTRIBUTOR ADAPTER OBD0 TO OBD1 CONVERSION:eBay Motors (item 200417193459 end time Dec-18-09 18:35:54 PST)
conversion harness for the ecu would be needed yes.
might have to change the fan switch sensor connector end and the injector clips, unless you use your obd0 injectors
just some of the stuff i remember when i droped the Z6 in, should follow suit though with a b-series
racist-bigot-sexist-homophob
how do i convert my old harness to multi pooint?
Fucking google dan! Damn bro you've been around here long enough to know better.
Defender of the D
I got a b18a1 i'll trade ya.. lol. good luck wit gettin ur shit runnin.
93 integra ls b18c
they have full conversions harness if you don't want to do all the work.
1 - 9 of 9 Posts
