1 - 3 of 3 Posts
Hello,
One of my B16A2's injector Head protection is Broken (see the picture attached)
Auto part Automotive engine part
I was thinking about remove this protection and make the head clean.
Somebody knows if i can use it without this plastic Head protection ?
I'm not sure that this kind of protection change something because i dont have that on other's brand injectors
The injector is still usable if the tip is not damaged.
I would not personally want to use it, but the plastic is there just to protect the tip. You could remove it and the injector would work just fine. Handling it outside you just need to be very careful now.
Tape-R taper/driver
EC3, ED8, ED9, EE5
Make sure the exposed pintle is straight an not disturbed.
Yes, you can run it without the "pintle cap" or if you'd like, you can send them to us for a service and we can clean the injectors and install new pintle caps, orings, and seals.
1 - 3 of 3 Posts
