1 - 2 of 2 Posts
someone correct me if I wrong cause I doing this from memory and I'm tired. The rod's length is the same as the USDM D16Z6 at 137mm. However if you user z6 ( P28 ) Pistons they will stick out of the deck, cause the piston's in the JDM D15b are ( P08 ) I think. is this correct info guys? Also run a search on JDM D15b, their is tons of info out their about this motor. just takes a little digging.
1 - 2 of 2 Posts
