1 - 4 of 4 Posts
C
This is a simple instalation and is a nice upgrade if your stock one is going out. I got mine set a 38psi which is the max for a stock fpr and the gauge is also accurate as I checked my stock FPR reading and it was around 26psi after I installed my B&M fpr I could actually feel the diference on responce. It great for Turbos and engine build up with crazy cams.
J
how much did you get this for a for how much? does it make a difference?
C
transzex said:
$59, makes no difference if old FPR was working correctly.
$80 FPR and Gauge shipped at:
http://www.honda-tech.com/zerothread?id=614500
And yes it makes no difference with stock engine but once you start putting in mods such as i/h/e, crazy cams you will need it if you want the best output for your mods. Of course it works better with turbo since you will need more fuel.
1 - 4 of 4 Posts
