1 - 4 of 4 Posts
D
Included in the kit, you will find a new banjo bolt and a 90 degree brass fitting and crush washer along with the fuel pressure guage. Your first step is to pop open your gas cap to relieve any pressure in the fuel system. Then remove the banjo bolt from the fuel filter.
With the stock banjo bolt removed, install the new banjo bolt. Be sure to install the new copper crush washer onto the banjo bolt first. Tighten the bolt down.
Now wrap the the 90 degree brass fitting with some teflon tape and install it onto the new banjo bolt. Be sure that it is tight and faces in the correct direction. Wrap the threads on the new fuel pressure gauge and install it onto the 90 degree elbow.
Double check that everything is tight and close the gas cap. Now you can start up the car and verify that there are no leaks. The guage will now display your current fuel pressure.
Good writeup. I do take issue with the use of teflon tape on fuel fittings. I prefer paste to the tape because if any of the tape ends up inside the fuel line, gas will turn it to mush and send it down the line. The tape can be used, just with caution.
P
anybody know where i can find replacement banjo bolts. i didnt get the kit, i just have the gauge. thanks.
1 - 4 of 4 Posts
